Why does the back button not trigger comment macros? The default should be to trigger them unless you do something like pig+back to disable comment macros.
I would say that generally the back button is used primarily in tech as a sort of "Go back and re-rack" option. therefore comment macros should not trigger.
That being said, an option was made in the list options to trigger comment macros when going back. Under the standard and main tabs. (This is off by default)
Please upgrade to 3.11.0 if you do not have this feature.
