Hello.
I want messages to appear when hardware limit values are reached. As if the backup battery is too weak etc. visible during normal work.
We who have worked with Hog for a number of years, know how vulnerable it is with, for example, a flat backup battery.
I sat bored at a meeting one day, and went through the hardware diagnosis, and accidentally found a red line that showed low voltage on the backup battery. This limit value, which gives red writing in diagnosis, should trigger a message, visible in the command field or elsewhere where you see it without looking deep.
