I posted the following on a Window 8 Forum, no response so I though I would try it here.
"Ok I'm using a Dell inspiron 15 series 7000 laptop w/ Win 8.1 Intel I5 and a 23" Hannspree external touch monitor. I use this system to run a single application" (Hog 4 PC) "that uses 5 open windows. I have arranged the open windows with four of them open on the external monitor" (The four monitor windows) "and one on the laptop display." ( the Hog 4 virtual desktop) "I want to "freeze" this window arrangement...ie if the system goes to sleep I want it to awaken to this arrangement not stack all the windows on the laptop monitor, also when I close the laptop, I want to keep the same four windows open on the external and not have the window #5" ( the Hog desktop) "jump over to the external monitor, and then when I open the laptop I want it to look like it did when I closed it, not having all the open windows jump back to the laptop monitor. Can I do this?
I know this is more of a windows issue but I'm sure there are some Hog PC users that might have a solution to this. Hopefully.
