And if i want to remove the position values from the position directory? Because i have one position that i have to record in a cuelist. my other position macros merge other positions into that master position so i can change it on the fly. But i haven't been able to remove position from that master position
The steps are: [ Record ] [ Macro ] # [Enter] -- to start recording Open the palette Hold down backspace and hit position [ Update ] [Pig] [Macro] to stop recording.
I just tested this in Hog 4 PC and it should work. You might want to adjust timings to speed it up.
