I ran into a programming situation today with a wall of LED's that made me wish there was a way to Hold or Stop an effect mid stream and then be able to pull the raw parameter values that sum up the look onstage into the programmer to possibly be used somewhere else in the show.  As it stands now, I can slow the rate of an effect down to zero and "hold" the effect, but I can't grab the raw values that are a result of the effect.
Also, it would be really cool if you could snap an effect to a predetermined rate via a "Rate pallette" etc.
JB
