Effect high and low value
Maybe it's an idea to have an effect hi and low value.
With these values you can set for example a high color green and a low color red. You can adjust those high and low value colors with macro's to have more freedome with effects. Beside this you can build one effect and use plenty of preset high/low values to ajust that one effect.
Parents
  • As it stands today, that is not possible with the effects engine. To get this functionality you can create a chase between two cues, and just update the palettes that are in them.
    This is logged as H4OS-3185 I will add your information on to it.
Reply
Children
No Data
