Has anybody experiences about using the OSC with other computers as remote controllers?
I'm working with a Roadhog, which has no built in Timecode/Midi slot. I want to synchronise my cuelists with the Medialon system, which has a built in OSC control unit as well.
Somehow the roadhog doesn't react on the Medialon commands.
The network connection is ok, Touch OSC over the iPhone is working fine on the same time.
There are examples how to write the commands in the manual, I'm not sure, if I write the commands correctly in the Medialon command line.
Are there spaces in between the commands and the "/" ?
Actually I need just a single "go" command from the Medialon system…
