Internal DP question
Hey. Sort of a curiousity/theoretical question.
If you have two Hog4s running live backup (both set as servers, on an ethernet switch) and you're running data out of the internal DP on console 1, will you lose signal communication if console 1 suffers a software crash?
Obviously you will if it loses network or loses power.
Parents
  • Even if you are using external DPs you would need to have 2 if you are trying to setup a full-redundancy.
    With the method described above you can handle 95% of the typical backup-situations
Reply
Children
No Data
