Ran into some challenges networking a Nano (with a Lenovo all-in-one touchscreen running 2.6.0) using sACN into an existing theatre's lighting network. The theatre uses an ETC Eos, 2 CEM+ sensor racks in universe 1, and D60 vivid LED fixtures and Mac 250 Entours in universe 2. Went to the DMX processor settings, fixturenet tab and set up static ip addy and in the sACN tab enabled 2 ports (1 @ universe 1, 1 @ universe 2).
With the Eos off, brought up conventionals to focus and the fixtures would black out between 1-3 seconds. Brought up different fixtures and same thing would happen. Checked the dimmer rack for errors and it listed "config mismatch 2". Then tested the 250's out and the fixtures would pan left but not right and tilt forward but not backwards. the console would show pan value @ -270 or tilt value @ 144 but the fixtures would stop at 0.
For troubleshooting did the basic power down/power up, swapped rj45 cables, swapped ports in the switch, changed ip addy, used a different computer to run Hog4 with different ip addy. Nothing worked. We then disconnected the Nano from the network, booted up the Eos to double check the rig and everything worked fine. Left the Eos online, connected the Nano back into the network and the conventionals were stabilized so no more black outs occurred. The pan/tilt issue with the 250's remained.
Have I missed something in my set up? Any recommendations what to try to fix the pan/tilt issue or the conventionals issue so we don't need to have the house console inline?
thanks in advance,
Cory
