Show database init failure
Recently I tried to connect a Hog 4 PC to a Road Hog 4, when I set up the Hog 4 PC as a server (net number 1) and the Road Hog as a client (Server turned off, net number 2) the Road Hog would see the currently running show and when I tried to connect to it and it starting to load the show database, the Road Hog gives a "Show database init failure" error message.
I tried swapping net numbers, changing ip addresses and enabling dhcp server but could not figure it out.
I'm currently running version 3.3.0 (b1175) on both systems
Parents
  • Can you connect if going from the RH to the PC?
    Do you have all other network adapters disabled?
    Are you running as an administrator on your computer?
    Do you have your UAC turned off?
Reply
Children
No Data
