Road hog 4 info
I have to know some info about the Road Hog 4...
I see that there isn't the trackball on board ... it's possible to use an external usb trackball? HES have a specific one?
For my work I need 12 dmx output ... I see that the console have 4 on board and up to 8 universes of DMX 512 over ArtNet or sACN ....
with a console + dp8000 I can use 12 DMx output? (4x internal e 8x dp8000)?? or more?
How many external touch screen can I use? HES have specific one?
  • RoadHog 4 have 8 DMX universes, 4 onboard.If you need more you can use DP 8000 (16 DMX universes, 8 physical output)
    You can plug an external usb trackball that can be used as mouse, but I don't see how to use it for Pan and tilt.
    You can use 1 external touch screens, from elo touch, references are in the section 3.1.8 p53 of the hog 4 manual.
    Hope this help
  • Roadhog4 can have one external monitor or touchscreen. It also has Hognet , which allows you to add a DP8K.
  • So I assume you can use any brand of artnet>dmx node to get 8 universes?
  • I love the trackball and not the mouse because the Track don't need space for movement...
    BUT move Pan and Tilt with the ext track will be very nice:) or improve the Trackball on the Touch screen.....
  • Is it possible to use a Super Widget on a Roadhog 4...(?)
  • [QUOTE=hagberg.dk;63648]Is it possible to use a Super Widget on a Roadhog 4...(?)
    Yes. Unlike the Roadhog3, the Roadhog4 is expandable.
    Hope this helps. :)
  • May I use the Hog3pc or Road Hog programming wing with the Road Hog4 ?
    and the programmer wing trackball is working with the Road Hog4?
  • [QUOTE=F250770;63656]May I use the Hog3pc or Road Hog programming wing with the Road Hog4 ?
    Good question!!!
    The wings are working with HOG PC in Nano Mode, which is the same layout like the Roahog.
    So probably it should work
    But for a 100% correct answer some HES Stuff needs to answer this
  • External Trackball Support
    The Hog 4, Full Boar 4, and Road Hog 4 consoles now support the following external USB
    trackball devices as native console trackballs:
    Kensington SlimBlade Trackball (Model K72327US)
    Kensington Expert Mouse (Model K64325)
    Kensington Orbit Wireless Mobile Trackball (Model K72352US)
  • Hello
    Yes if you hook up an H3 programming wing to a RH4 and put the wing the 'POS' mode you can use the trackball on the wing to positon the lights.
    As was stated in the above post we now fully support the following 3 external trackballs.
    - Kensington SlimBlade Trackball (Model K72327US)
    - Kensington Expert Mouse (Model K64325)
    - Kensington Orbit Wireless Mobile Trackball (Model K72352US)
1 2
