[Question/Request] Hog3 Wings w/ Hog4
Using the Hog 3 wings on a H4PC and I cant find a key combination on the wings for the "Cue Back" function. I know the new lines of consoles have the back key, but is there a key combination on the H3 wings that will duplicate that function?
If not.... I would like to request that maybe a combination of Pig+Hold on the H3 wings might give us the back function.
JB
  • There is not a key combo to make the new "play backwards" key work on holder hardware.
  • Thanks for the reply Chris.
    Would it be too much to ask if you guys could implement a key combo on the H3 wings to implement the "Play Backwards" function?
    After all, the function exists in the keyboard map mode.
    JB
  • If you need a Play Back hard key, you can configure the "Pause" key from Cuelist options to do this instead of the default Halt/Back functionality.
    Hope this helps. :)
  • Marty,
    Thanks for the reply..
    I was aware of that, but unfortunately it's one or the other. The hold key no longer goes back after a second press and if you configure to Playback, then you lose hold.
    JB
  • [QUOTE=Buzz313th;64222]I was aware of that, but unfortunately it's one or the other.
    Probably just something we'll have to live with when using the previous generation of hardware.
  • [QUOTE=Buzz313th;64211]Thanks for the reply Chris.
    JB
    Sometimes engineering scoops up feature requests directly, an example being a way to disable the rate wheel ( see forums.highend.com/showthread.php?t=13887 ).
    In this case, I should defer to others :147:
