Updating DP8000 to v1.0.1
Hi All,
I have finally got my Hog 4 system back in the office so have been updating it to the latest release v1.0.1.
The full install from USB on the Hog 4 went without a hitch, but once again I ran into trouble getting my DP8000 to update itself on the network. This is something I used to have with the Hog 3 and was hoping the issue would have gone away with the Hog 4.
Even though the DP8000 was visible on the network and could tell that it had the older software (v1.0.0) it would not update. Even when I forced a software update by holding the 3 buttons down on power up it would not do it. I had DHCP and Boot Server selected on the Hog 4.
I had to connect the DP8000 directly to the Hog 4 with a crossover cable and then it worked by doing the force update command...it still would not update by sending the command from the Hog 4.
Does anyone else find this?
Cheers
Colin
Parents
  • That looping is what was happening with my DP8000 with the Hog 3, although it did update with a direct connection with crossover cable.
    I did not have the same with the Hog 4 this time, it just wouldn't start the process at all when connected through an unmanaged switch.
Reply
Children
No Data
