cuelist rate size
i'm not sure if it's still on version 1.0.1 but i actually use 1.0.0
setting back my rate size to 100% by pressing . and using the encoder shell doesn't work!
  • Swolf
    What is this process setting the value to?
    I noticed that we set the value to 90% just as we did not Hog 3.
    Are you seeing something different?
  • it's not what i am seeing.
    default rate size is 100%. during my show i set it a little lower for changing the effect speed. when i try to set it back on 100% by using the dot (.) button in combination with the encoder wheel it is written for example 36%+64%. so far so good. but the default rate value of 100% will not accepted.
    means the effect is still as slow as i set it before on 36% of the whole speed range!
