Fullboar4 + OSC Rate wheel
hi,
I connected my Fullboar4 (v1.1.2) on my Ipad via OSC.
I can control everything except the rate wheel.
I checked on Hog4Pc and rate wheel work fine on osc
I'm sure it worked in previous versions, is it normal that it does not work now or I do something wrong?
Regards,
Gael
Parents
  • The rate wheel is not supported on the FB4, so there is no OSC equivalent. If you pull up the MIDI viewer you will most likely see "rate wheel is not supported" messages.
Reply
Children
No Data
