04-22-2013
v1.1.3 b352 Hog4 and Hog4 PC
Reference pallet doesn't work properly with several different data.
I.E.
Make (gobo1 "First gobo”) Global or fixture type Pallet.
Make focus Pallet with several data as "Gobo1/F".
I.E. Fix1 has 10% Fix2 has 20% and so on.
Select several fixtures and select "First gobo" and "Gobo1/F" and merge as reference and per type pallet.
You could see gobo1 and "Gobo1/F" data inside of "First gobo" as per type.
But if you select  "First gobo" pallet.
You couldn't apply focus data.
In this case, you should merge as reference and per fixture.
Then it will be work.
Aki
