using OSC to update position Palettes
So,
How are people using OSC to update position palettes??
My normal touring workflow for updating positions is as follows,
I make a cuelist with each position, with only the fixtures that need to be updated.
I then update the fixtures using the update button, and select the palettes, (obv deselecting the cues)
This however does not work with the OSC remote, as you cannot select the correct option on the touchscreen.
I suppose I could manually load each position, but then I am at the whim if I type in the correct palette, with no feedback on the screen.
Has anybody created a simple work around to make this easier?
Joshua Wood
Parents
  • Josh,
    Could you make a new page in Touch OSC with various buttons that say "Update Pos. X" "Update Pos. Y"...etc...
    Make your adjustments as needed...hit the tab and update the right position??
    Then make macros on the console that those trigger??
    Just a thought...
Reply
  • Josh,
    Just a thought...
Children
No Data
