BUG - Cuelist options shortcut bar
RH4 1.2.0
Holding down "Choose" on a master brings up the 'Cuelist options shortcut bar' below the command line. (Don't know precisely what it's called, couldn't find mention of this new-ish function in the manual).
Opening the 'Cuelist Directory', and holding down a 'virtual' list palette also opens the 'Cuelist options shortcut bar'. However, none of the options are selectable (would require a multi touch).
(Discovered this when trying to change a bunch of virtual lists to "reset on release" without opening each list.)
Parents
  • Correct, I know it was released near the end of Hog 3's development, I was describing the function since I didn't know what it was called. It's one of my favorite features.
    I was just pointing out that it also appears when holding down a virtual list palette, but the options that appear are unselectable. I propose hiding them until the multi touch is enabled.
Reply
Children
No Data
