Positon+Time+Time problem
I know there is a very simple solution to this problem, I remember doing it at HOG 4 Training and now of course I am on a gig and the one thing the LD wants I cannot seem to make happen. Long story short I have 4 20' Vertical Trusses. Each of the 4 verticals have 4 movers hanging off the front via sch. 40 pipe. I have the fixtures aimed at FOH for eye-candy and need them to change from one color to another, but starting from the top left and working its way to the bottom right of the stage. I know it has something to do with position or colour+time+update, but I cannot remember the button combo, any input would be greatly appreciated!:hogsign:
  • Select your fixtures in the order you want them to change...
    Select the color you want them to go to...
    You then need to delay the color parameter..
  • Check out Colin Wood's EXCELLENT video tutorial on editing cue timing.
    www.highend.com/support/training/Hog4Training/Video7.asp
    Relevant to you starting at 2:20 onward. You'll be editing the delay timing of your color parameters, probably fanning them by truss.
  • Just a note. It is possible to use multiple thru. Like 1 thru 10 thru 1.
