I have a rh4 that I often use with a playback wing. I often have the playback wing connected but from time to time on the smaller shows I have no use for the wing. The wing always connects fine but I have troubles when I go from a show with the wing connected to a show without it. The screen works fine but its rare that the touchscreen functions on the second screen properly. It usually takes a screen calibration and restarting the console for the touchscreen to function properly. When I start a show with the touchscreen connected and the last show(same show file) also had the wing connected things are fine.
Is there a certain order I need to connect things or turn things on in order for the touchscreen to function from the beginning if I didn't use it the last time I ran a show?
