I'm struggling to understand why when we press GO with an IPCB fader, the values immediately go to their full programmed level, and the fader level is ignored.
I have rolled back several versions of the software as I was convinced at first this was a bug, but it has existed continuously.
Is this useful and intended, or in fact a bug that has slipped through the net?  For me it seems inconsistent and it caused me a headache recently.
My feeling is that when a fader is set to IPCB, it should control all parameters in exactly the same way that a fader set to just intensity works for the intensity parameter.
When I have a standard list and I press GO, my fader level continues to limit the programmed intensity proportionally.  All other non intensity parameters change to their programmed levels.
So, when I place all parameters under the control of the fader, as IPCB, then I believe the fader should continue to have proportional control of these parameters even when GO is pressed.
Does anyone have a reason why I am wrong to think this?
