I have downloaded everything with v2.4 and touch OSC including the new template with command line. I have networked them and can fire cues and such from my laptop as well as select fixtures and properly use the command line. What I CAN'T do is use any of the encoder wheels or faders. Is that normal? I sort of doubt it since it's pointless without these features. When I use the encoders from the console, I can see the changes on OSC but when I try to use the encoders or faders from OSC, the console is unresponsive. Is anyone else seeing this issue? Have you found a fix for it?
Again, thank you for unlocking this feature for HogPC users, hopefully this is able to be resolved.
