I know I can create a Kind that will separate the Position parameters (e.g. pan & tilt). However, swapping between the 2 states (separate and back together) does not seem to work for me. For example, if I select a fixture in the Programmer, press the Kind button I created to separate Positions parameters and then turn the tilt encoder the pan value remains untouched. This is what I wanted. However, if I want to join them back together for the same fixtures or some other selected fixtures pressing the default Position does not work. I even created another Kind as a copy of the default Position Kind and added it to my Kinds directory with the same result. The only was I can get it toggle back and forth between separate and non-separate is to clear the programmer and start over. What am I missing?
Kevin Montagne
