Hog 4PC with DP2000?
Hello, I was doing one looking around online yesterday, and discovered that "the DP2000 will no longer be functional within Wholehog software versions 3.2.0 and greater." (According to the Trade in and End of Service information for the DP2000). My question is if this is referring to the firmware running on the DP, or if I can only use the DP with the HOG 3.2.0 PC software. Can I use the DP2000 with HOG 4PC, or only up to Hog3 PC v 3.2.0?
Parents
  • All depends on your computer... If you only have one networkport hognet and fixturenet will share the same port.
    If you have to you have to set the IP to the matching IP range of your fixture net port.
    Dont forget to switch the DP2000 to the Artnet mode
Reply
Children
No Data
