Bug Report - v3.0.0 (b1049) - Choose indicator on screen incorrect
I've found that the onscreen fader view (1-10), the "dark blue" Chosen indicator is not correct. I can cycle choose buttons on various faders, but the blue border does not change with the chosen fader on the screen.
Also, if you touch the faders on the screen, the "choose" indicator is one behind. Tap on the lists to "chose" them and continue down the row. The Choose light will light up accordingly, but the indication on screen is one behind.
Parents
  • Chris, if it helps, my workflow yesterday (Though not exact) was upgrading RH4 to 3.0. Built 2 plots and 1 pixel map. But it seemed to me that from the initial boot into 3.0 (just opened the previous show file…no merge) the Choose/GM issue was there. Upon reboot it was gone. I'll keep an eye out though for sure.
Reply
Children
No Data
