Hey gang, I'm trying to configure our Road Hog 4 to talk to ProVideoPlayer 2 via ARTNET.
I have an ethernet cable out of the fixturenet port hitting a switch, then from there a cable running sACN to our dimmer racks, and another cable, im hoping to run ARTNET to our IMAC running PVP.  The dimmers still work fine but I cant seem to configure PVP2 correctly.  Should the imac's IP be in the same range as the fixture net output, and then the ART NET address in PVP2 match the ART NET address in the network settings of the DP8000?  Not getting much response but im unsure if I have it configured correctly.
Any help?
