Unable to connect Hog4PC to Capture Argo
Hello,
Since 3.2.1, we are not able to connect our Capture Argo with Hog4PC. Capture doesn't show any external universe as before. Also, we found that the connectivity windows does not appear anymore. We checked everything we know, like the connectivity on the open window, the IP address, etc. Please help as we need to pre-program a show this week, and nothing's working right now!
  • Have a look here:
    www.youtube.com/watch?v=qPzJNnR-oa8&feature=youtu.be&list=PL0A80EBF9DAD9389A
    This is for Lightconverse but the steps are the same.
    Major changes since 3.2 in the way you connect to a visualizer
  • Hello. I followed all instructions in the video. My problem is I can't put a dedicated ip address since I can't lose my Internet connectivity since I need to go on internet with my computer. With the old version of Hog4PC, it wasn't a problem. Now, if I use the connection via DHCP to continue to connect on web, the visualizer is on status idle, and Capture does not connect to Hog4PC. That's not good !!
  • Are you running Capture an HOGPC on the same computer?
  • Yes I am. I found later this morning that is working when my computer is completely out of any network (wi-fi or lan). At this time only, I can see the Capture ip address, which is in this case 127.0.0.0. As soon as I turn on the network, it's stopping working.
  • Has anyone found a way to connect hog and capture and still be able to have an internet connection? If I could get this to work I could share my screen with the lighting designer and do design work without having to be in the same city as the designer.
