Position Effect Fader
Ok, so I have recorder some beams at 2 differ positions on a fader. Cue1 and Cue2. Fader is set to GoWhenOff0, and I have recorded the same beams (while that position is active so as not to record position parameters) with a circle effect to another fader. The problem is that every time the 1 fader is fired after the effect it stops the position effect. I recorded the effect as effect only. I recorded the positions as positions only. I know I missing something. I want to be able to be in any position and start the circle effect, keep it running and go to a new position.
Parents Reply Children
No Data
