Pretty major network bug in HogPC
Hey chaps, upgraded to 3.3.0 and I've come across what I think is a pretty major problem.
Unless I'm being a massive idiot and missing something HogPC won't let me configure or use any network interface that isn't active (i.e plugged in and negotiated) and defaults the console to a local loopback address.
this is a pretty shocking problem as even once an ethernet cable is plugged in it won't recognise it so you need to exit HogPC and go back in for it to work.
I've tested this on three PCs now and they are all the same, previously this did not happen.
Parents
  • I was seeing this on a Surface 3. It defaulted to a loopback adapter only (greyed out, couldn't change it).
    Briefly played with the Windows network settings, and confirmed I was on the wifi network.
    Tried to do a wired network, but my apple ethernet adapter wouldn't work on the surface (shocked).
Reply
Children
No Data
