So Im wondering how often tge gel number palletes are calibrated ?
Example Im using the Arri Skypanel in gel mode (m16) soon and Im wondering if I select Lee 201 will that correspond to the channel 6 value that is set in the lamp for lee 201 or even in rgb mode (6) will the lee 201 pallette work no mayter whether the lamp is set daylight or tungsten ??
Just trying to get it in ny head ahead of time as im hitting the ground running on friday
Cheers
Mikey
