Reasons to go with Hog
I have toured exclusively with Hog consoles for the past 4 years, and just started a job where they own a bunch of ETC consoles. My supervisors are open to making the switch to Hog, but only if I can justify it with reasons (and not just wants and comfort) for leaving the ETC line. We currently have an Eos and Ion. Any technical or factual reasons why making the switch to Hog would be greatly appreciated.
  • Hello,
    I hope given the Hog User Base here, you will get multiple replies from some of the power users. Obviously most replies will (and should be) bias towards Hog.
    I have almost exclusively programmed on Hog. I worked with earlier ETC consoles (Insight, Expression, etc.) and only stumbled through using an Ion a few times. From my perspective, I had a lot of trouble efficiently controlling a number of moving lights.
    From my perspective, I feel like the Hog can control conventional lighting as well as it controls moving lights and LEDs. However I don't think the ETC efficiently controls Moving lights as well as it controls conventional based on MY experience. I understand that an experienced Ion programmer can easily make the counter argument. it ultimately depends on the programmer.
    Ultimately, I think the best argument you can make towards going for one console is you. If you can program a Hog faster than you can program an Ion, and you can save productions time/Money, then that is an excellent reason to get you the console you need. Below are couple bullet points, I hope they help. You should also consider posting your question on the Wholehog 4 User Group on Facebook. I think you will be overwhelmed with the replies there.
  • Hardware Improvments:
    Larger and Higher Quality Displays
    3-Axis Trackball (Hog 4 & Full Boar 4 only)
    5 Encoders (Hog 4 & Full Boar 4 only)
    Front Panel Display & Jog/Shuttle dial (Hog 4 only)
    Built in Keyboard (Hog 4 only)
    Multitouch Capable Displays
    Motorized Faders (Hog 4 & Full Boar 4 only)
    Dedicated Grand Master (Hog 4 & Full Boar 4 only)
    Assignable Front Panel Function Keys
    Built in DMX outputs
    Separate Back and Pause Buttons (not HH4)
    Additional Pig Key (not HH4)
    Solid State Drives for speed and reliability
    3 External Screens (Hog 4 only)
    Built in MIDI and LTC (Hog 4 and Full Boar 4 only)
    Storage Drawer with USB power (Hog 4 only)
    Software Upgrades and Reinstalls in minutes
    Softwareware Improvements:
    Plot View & Pixel Mapping
    Compound Fixtures
    Media Integration and CITP
    User Kinds
    Playback Scale Masters
    Assignable Command Keys
    Fast New Shows
    Video Matrix Control
    DMX Test
    Visualizer Bundled
    Reporting, Print to PDF
    Lock Screen
    OSC Remote Control
    XML Import/Export
    Menu Window
  • Plot View
    Graphical 2D view of fixtures
    Create within seconds using touchscreen or mouse
    Powerful layout tools: line, grid, circle
    Drag to select fixtures using line, rectangle or area
    Intensity and color feedback for instant awareness
    Pixel Mapping
    Most powerful pixel mapper in industry
    Pixel map built using plots, not grids
    Accepts images and videos in any format
    Totally self contained, no external hardware needed
    Playback completely integrated with existing lists
    Compound Fixtures
    Schedule entire fixture at once
    DMX patch all parts at once
    Display all parts together
    Fast selection using dotted numbers
    Lateral selection
    Use “.1” or “.2” to quickly move between parts
    Gobo and Color thumbnails
    Import media server thumbnails
    Stored in show, available offline
    Thumbnail images shown on toolbars and in dedicated Media Picker window
    User can provide custom images and names
    User Kinds
    User defined collections of parameters for fast direct access to any part of complex fixtures
    Automatically created and assigned to hardware buttons for ease of use
    Fully configurable encoder assignments via drag and drop
    Also use as masks during programming and playback
    Scale Masters
    Rate Control via Faders and Buttons
    Control Fade Rate, Effect Rate or Effect Size
    Increase/Decrease via Fader
    Double/Half Rate via Button
    Quickly switch between options
    Command Keys
    Command Keys make Function Keys into executors
    Assign Any Lists, Scenes, Macros, etc to hardware buttons
    Fast, direct access to anything in a show
    Fast, Small Show Files
    New Shows start in seconds
    Easily import fixture types from external libraries
    Show backups are small and fast
    Show files remain self contained
    Video Matrix Control (coming in v3.5.0)
    Direct control of video matrix switchers over Ethernet
    Specific models from Barco, Lightware, BlackMagic, etc
    Seamless integration in library, programming & playback
    Sync video and lighting playback in a single cue
    Allows consolidation of roles
    A single operator can now run larger more complex shows
    A dedicated video operator now freed up for other tasks
    Hog 4 - Aggressive Release Schedule
    Hog 4 is moving quickly
    Frequent releases – every 3 months on average
    15 major software releases since inception
    New features added regularly
    Will continue for the foreseeable future
    Hope this helps.
    Feel free to contact me directly if I can help.
    paul.hancock(at)barco(dot)com
  • Thanks!! I am looking forward to gathering more points!
  • I am not trying to be that guy. But I was wondering if any of the more experienced users have any suggestions? Thank you in advance for your responses!
  • A console is truly a personal choice.
    As a programmer, I want what I will be fastest and most comfortable on. I generally program on Hogs and Ma2's, but the occasional ION/EOS line as well.
    If it's a rental house, he should rent what is asked for in the area. Generally, I see Ion/Eos on theater style shows and Ma's and Hogs on concerts. As Paul stated, a console is purely a personal choice. If the rental house is always sending you out with the console, then whatever console you are fastest and most efficient on will save the client money in the end. All consoles do the same thing...spit DMX. It falls to the GUI and what the programmer is comfortable with to make them "sing."
    I'm fastest and most comfortable on a Hog. I can do 90% of what the Ma can do on the Hog. For 99% of the shows I do, you don't need that last 10% of the Ma firepower. Then there's cost. Consoles are expensive. For a rental house, if he can't get a ROI on console purchases with rentals, then it doesn't make sense to change.
    It's purely up to you to sell what you are worth. If client time and money savings is important, then it sounds like the Hog is the way to go for you and your boss.
  • I totally agree that a console is a personal choice, but I do think that some consoles are made for one application more so than others. In the past, I have generally programmed on Hogs and Ma2's as well, but I was also doing live concerts and events on the road. Now that I have spent 3 months with the ETC's in a fixed venue I find them lacking. I think they serve theaters, brodcast, and video recording studios very well. But with live events and music, I personally see the Hog's handling the demand better.
    All that to say, my personal feelings don't matter in this decision. I am looking for factual reasons (hardware or software) the Hog's are better for live music than theater. Hope this makes sense.
