Fullboar Group Directory Maximised, if you unlock and try to resize to 19 Pallettes wide you cannot, it jumps from 20 to 18 pallets wide.
Hedgehog Group directory maximised. If you make the button smaller and try to resize to 20 palettes wide you can't. You can only do 19 to 21 wide.
In itself you might not think this is to much of an issue but if you store palettes on the Fullboar then connect the Hedgehog you can not view the palettes as they were on the Fullboar!
I tried doing this on external monitor, changing buttons sizes made no difference.
