Mark time on Cuelist with Intensity Effect
Hi, I created cuelist with intensity effect. However, the mark time is not working with this cuelist.
This cuelist also ignore the delay time I put on the intensity.
Any help is appreciated. thanks
  • Delay on intensity does not automatically put delay on the effect that you use on thhe intensity base value.
    Maybe this is what you are seeing.
    Marking is only working for fixtures with 0 intensity. if you have an an effect running on intensity there is no 0 intensity
