Hello all,
I have encountered a problem, I am not sure if this is due to the 3.8.0 software update. I seem to have trouble using the suck feature on random fixtures. Some it works fine, others it has no effect. This has nothing to do with fixture type because it both works and doesn't on some of the same fixtures in my show file. I have also found that whatever fixtures I cannot suck, if I try to adjust any of their values with the knobs, they instantly reset to their default value. Ex. If I barely tap the pan/tilt knob, it instantly resets to 0. This makes it incredibly difficult to program with as the only way around this is to open the cue I am trying to suck values from, write down the values, and re-enter them in.
I am running on a full sized Hog 4.
-J
