Hog OS 3.10.0 - Bugs
My desk crushed 2 times - with very interesting screens and flickering. I used an external wireless usb keyboard. I tried another one - noticed the same issue. After I diskconnected all external USB devices, the console was working fine.
A friend of mine noticed crashes with another Road Hog 4 - same OS version, using a Hog 4 faderwing. The console crashed, when he stored views - without the faderwings touchscreen - the console is working.
Is there a problem with external USB stuff in 3.10.0 ??????
  • Generally, external USB devices should work fine, as long as the device does not require installing any additional drivers. I have noticed that some wireless keyboards and mice do not function with the Hog4OS.
    I would recommend using a generic keyboard and mouse.
  • Well, I will have to do. But i´ve used thoose keyboards many times before - without any problems.
    But what's up with the external screen - touch screen.?
  • Would you be able to specify what peripheral devices you are trying to use?
    When you updated the console, did you have anything plugged into it either via USB or a monitor? If so try a fresh install of 3.10.0 again without any extra devices plugged in.
  • I fixed that issue ... ;) Thoose Keyboards are in the bin now.
