Hi I wonder can I make an effect using more than two palletes?
I know I can do it with 2 " effect@position 1 thru position 2"
Also when I do this I must type "position 1" because if I call it with the name given to it it doesnt work
Effect @ Position Palette_1 thru Palette_2. I get this a lot when I have to open the palette window first before tapping on the palette.Effect @ Position Palette_1 thru Palette_2, you will need to get rid of the Position before hitting enter. The command line should read Effect @ Palette_1 thru Palette_2www.etcconnect.com
