2 version hog pc
There is some way to have 2 versions of HOG pc on the same computer
  • You should only be able to install one version of Hog4 PC onto your machine.
  • It can be solved.
    Save the first installed version to pendrive. (eg name Hog4V8)
    Then install the second version overwriting the original.
    Once the installation is complete, copy the old version to the machine with the renamed directory name and you can use all 2 versions.
    So I use 2 H3pc versions and 2 H4pc versions.
