BUG: Record/Merge selected only
When I touch fixtures 1 thru 10, so that all the parameters are active in the programmer. I suspect when I deselect my selection, by pressing the backspace button, that when I use record/merge selected only the desk will add an empty cue to my cuelist. But it creates an cue with all parameters. When I add an extra fixture without touching it, it will create an empty cue when doing a record/merge selected only.
In my opinion this is a bug. When I have nothing selected and using a record masking "selected only" it should record an empty cue.
Kind Regards
EJBerendsen
  • It looks like the code currently considers an empty selection as a way to not apply the rule.
    We are looking into this behavior more.
    Thanks for letting us know about it.
