Hello,
I had this years ago, and the bug seems to be back. New showfile started in v3.17.1. Currently a single Hog 4 with HPU.
When I use the DMX Test window, if I accidentally drag over patched addresses and they get “tested” they are being unpatched. The HogNet value disappears. They appear patched in the Fixture Window but must be manually repatched before they are controllable again. When the HogNet values vanish, the boxes still turn blue showing fixture selection.
I just want to stress, this is not a case of me overriding HogNet control by pressing Set and entering a value… this is happening when Test is used.
Please could you investigate?
Cheers
Colin
