In Hog4PC, I'm trying to use an IPCB fader to control the tilt position of some moving heads. When I set everything up to go, with the max position set in a cuelist, the cue playback percentage is double that of the fader position when I move the fader up and down. When I reach 50% up on the fader, the cue hits 100% in green. If I start pulling down on the fader before sending it all the way to the top, the cue playback starts jumping around in values. When I switch any of my other fixtures intensity control from I-fader to IPCB the same also happens.
When I do this at the venue on our console, I don't run into any of the same issues. I've played with every parameter I can think of but nothing seems to work for me. Also when I take a backup that works at the venue and load it at home, it'll work at first then after a log out it returns to being wonky. What am I missing?
