I'm trying to setup midi control of a hog4 pc. Right now I'm trying to use midi to control the main go button or go for a specific cue list. I can get it to work once, but then it doesn't continue to go. If I quit the hog and get back in it will work once again. Is there something limiting using the same note again and again? I've tested using master go and cue list go but once one command has gone I can't get any other midi commands to work. Manual controls still work, I can see the midi notes coming in on the midi viewer but it just doesn't respond to them
