Have you tried to recall the View a Second Time ?
I have the same issue on FullBoar with Cue list,s
CueLists saved views will only recall when there is a cuelist on the chosen master. If the chosen master is empty and the view is recalled then it won't recall the cuelist view correctly. This has always been so.
My issues have been confirmed by ETC support, and occur regardless of saved view or not. I even tried a clean show.
I have just updated to v3.19.1 and have found the same issue. The display is now far worse than before. There is a lot of wasted space between the rows of elements and you need to be able to drag the boundary of each of the different elements and be able to drag the horizontal scale separately to the vertical scale.
