Hello, I’m new to Hog4 and I cannot for the life of me figure out how to resolve the errors i get when trying to build this fixture. Any ideas? Fixture is a Prolycht 300fs in mode 3 (10 channel).
Your first issue with the CCT values means that the numbers you have picked are not valid for Hog. Your range is most likely too large.
Your Fan Control issue is because you cannot assign continuous DMX functions so no 0>9 or 10>75 pick numbers between those values like 0 or 10
