Bug Report - 3.20.0 - Desktop Crash on changing views
3.20.0 (build 3569)
RoadHog4 + External Monitor + DP8000
If I change between 2 views in my showfile it always crashes the desktop, unless I wait 1s before applying the 2nd view.
(I haven't tried this on HogPC... just the RH4)
I have the both Log files, and a showfile, uploaded to here:
https://1drv.ms/f/s!AmBhboDoAcXxgaYtoRJRt4pltb1wJA?e=ybre7u
Dan
  • I forgot to say,.... its views 25+26 that cause the issues
  • Hello,
    I see that view 26 has the virtual wing window, there is a known issue of the virtual wing window crashing the desktop upon recall. Your report is now logged as H4OS-9154 and we'll see if that might be your cause as well or if you have found something new. Thank you for your report!
