Bug Report v4.1 (b3728) Global Position not working on Selection of 13
Running a High 4 desk with one DP8K.
Found this bug on my show so I started a new show and it's still there.
Patched 20 movers of your choice.
Using one fixture, create a Home Position palette of Pan and Tilt at 0° as a Global palette.
Select all fixtures and randomly move their position off of home.
Record in a cue and play.
Clear programmer.
Select all the fixtures and hit Home palette...works as it should.
Select fixtures 1 thru 10 and hit Home....works as it should.
Select fixtures 1 thru 13 and hit Home...only one fixture does it.
Any other selection, 1-15, 2-13, 1-7, 1-18, and so on, works fine but 1 thru 13 does not and will not in any mover I try it on.
  • I haven't changed to v4 yet so I can't see if this happens for me but I'm curious... What happens if you select units 2 thru 14, or some other combination that totals 13 units? Maybe even 1 thru 8 + 11 thru 15, etc? And what happens if the position is something other than 0/0 pan/tilt?
  • I haven't tried a sum of 13 fixtures using the plus key, but it is any range of 13. I've tried 1-13, 101-113, 2-14, 801-813. Any other range does not do this. It is also not just with that one position palette. Any Global palette does this. So even a Global Open White palette will do this.
  • Hello! We were able to reproduce this. Doesn't seem to matter how you select 13 fixtures you just have to select 13 and this issue occurs. It's now logged as H4OS-9741. Happens with Global and Per Type (except Global Colour is fine)
  • Glad you were able to repro it. Not exactly the bug you want to discover on a show called Lucky 13....haha.
  • Hey Scott,
    We have resolved this issue in v4.2.0 and we just posted the first beta build. If you interested and able to beta test the software its available in the Close Beta Group.
  • Updated and tested today. All seems to be working now with Global palettes and selections of thirteen.
    Thank you!
