Hello,
I was running v4.1.0 with 2 consoles, both net 1 (but also tried net 1 & 2) and backups appear to be failing on the console that joined the network last.
Please see error message attached.
Cheers
Colin
Hello,
Cheers
Colin
I have this same problem. Updated to 4.2 thinking this would solve it but I;m still having this problem on multiple different shows/setups
colin wood Did you ever figure this out? Mine has the same red error with "Unable to retrive object for ID 5...."
Same here,
Client desk logged in on a show running on another desk is not able to make a backup even when this desk is running a server.
Hi Colin, I will see if there's a field report or bug reported on this and of not, will enter it into the system. We're grateful for you bringing this to our attention.
colin wood Don't know if you saw this thread, looks like backup on networked consoles is going to be disabled for the short term until this gets rewritten.
Bug - 4.2.1 b3764 still fails to backup when HPU is networked with console.
This has been fixed in 5.x software. All previous releases can have this problem
Thank you. Will test this week!
