Do you guys have any idea how I add a artfox solar eye k19 to hedgehog4? Or where can I find the library?
Hello,
If you navigate to this page https://www.etcconnect.com/Products/High-End-Systems/Hog-4-Consoles/Fixture-Libraries.aspx
you can see a section called Hog 4 Fixture library,from here you select software version you are searching for either V3 or V4,
You can enter then enter the manufacturer and fixture type you are searching for.
You will then need to download this library file and add to your showfile.
Hope this helps
