Timing Palettes
Timing Palettes Aigain.
Following Syntax: Groep 21 Color 12 Time 2 Time 0 thru 6 thru 0 Enter
This gives me a programmer with the values: Fixtures 1 thru 12 at Yellow, FadeTime 2s en DelayTime 0 thru 6 thru 0
When i record this into an TimeOnly palette and i open the palette afterwards al i see is Value nothing (as expected) Intensity Fade 1s Intensity Delay 2s.
There is no fadetime on the color and no delaytime on the color when i open the palette. Values are - If i select Fixture 1 thru 12 again and apply Color and the TimeOnly palette, the programmer gives me values on the Intensity and Color, with Show Palettes it also gives me the reference to the TimeOnly palette. When i switch of Show Palettes it just gives a blank -
Not sure if the palette works. I will check tomorrow.
Any idea why this strange behaviour?
Thanks Sander
