HI Hog World,
Is it possible to make a Palette with only Color Mix Values or Minus Green or CCT separately without storing other colour values.
Sorry, that I am not sure on how to figure this out.
Andy
HI Hog World,
Andy
Physical color parameters can be recorded separately into a palette if you assign them using Set with an encoder wheel, pressing the associated button on the Wheel toolbar or direct entry into a cell in the Programmer window.
Thanks Gideon.. I have one more ? How do you update or knockout values for a Per Type in a Palette . Is there a way to Merge non values. If I have more than one Per Type Fixture in a Palatte , but I want to remove the values of one of the per Type fixtures and not another. I can't use Replace and Merge can't merge no values. The only work around is to Record Remove and re-record only the values I need... I don't know another way.
You can update parameters in a Per Type palette simply by using Merge Per Type. And like you said Record Remove Per Type to knockout active parameters.
