If I try to reduce the intensity of a group virtually or through a group master , it has no effect on a fixture, if the fixture is in a PixelMap . Is this a bug or just not possible ?
is this correct?
Could it made possible?
Andy
is this correct?
Andy
Hello,
In v3 software this is not possible. You will need to control the fixtures intensity using the Pixelmapping Layers intensity.
In v4 software you can do this.
Thanks Michael.
Im using V4 and still not working .
Can you confirm it’s working ?
thanks
Hello,
I just tested on v4.2.1 and I am able to control Intensity values using a group master. Quick repro with rgb leds. This repro assumes you know how create a plot.
Thanks. It does work!. This time I put the Pixel Layer in the Group not the fixture as I had done last time. I am very happy now, thanks for the work through Michael.
In V4 it doesnt work for virtual intensity channels.
RGB 3ch cells with a virtual intensity.
group master of RGB cells has no impact on Pixelmapped content running
